Introduzione
If your Epson VS240’s bulb is burnt out or misaligned, use this guide to replace or realign the bulb. You will need a new bulb if your current light has burnt out or has had damage. A compatible bulb is a projector ELPL 88 bulb. You will only need a Phillips head screwdriver for this repair. In the case that the bulb to your Epson VS240 is damaged, please proceed with caution as some broken glass may pose a danger depending on damages.
Cosa ti serve
Unplug the device and let it cool for an hour.
Place the device on a flat surface.
Be gentle when inserting the new bulb. If you feel any resistance when inserting the replacement bulb, chances are that you inserted it the wrong way. This is a common mistake. Turn it around, making it face the right direction, before again inserting it into the device.
Be careful when screwing components back into the device since over-screwing can result in damage to the pieces.
1Commento della guida
I replaced the bulb in the projector, but it still won't operate, and when I removed and reinstalled a bulb in my other projector, it does the same thing now, How do I fix it even with a replacement bulb?
