Salta al contenuto principale
Epson PowerLite 77c Lamp Replacement
Cosa ti serve
  1. Epson PowerLite 77c Lamp Replacement, Lamp: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Epson PowerLite 77c Lamp Replacement: passo 2, immagine 1 di 1
    • Slide the cover toward you, then lift it to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Epson PowerLite 77c Lamp Replacement: passo 3, immagine 1 di 2 Epson PowerLite 77c Lamp Replacement: passo 3, immagine 2 di 2
    • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
    • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
    • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 17
Tutti i Tempi: 507
