Salta al contenuto principale
Enabot EBO SE Camera Replacement
Cosa ti serve
  1. Enabot EBO SE Camera Replacement, Wheel Assembly: passo 1, immagine 1 di 1
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
    Chiedi a FixBot
    Aggiungi Commento
  2. Enabot EBO SE Camera Replacement: passo 2, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 2, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 2, immagine 3 di 3
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
    Chiedi a FixBot
    Aggiungi Commento
  3. Enabot EBO SE Camera Replacement: passo 3, immagine 1 di 2 Enabot EBO SE Camera Replacement: passo 3, immagine 2 di 2
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
    Chiedi a FixBot
    Aggiungi Commento
  4. Enabot EBO SE Camera Replacement, Lower Housing: passo 4, immagine 1 di 2 Enabot EBO SE Camera Replacement, Lower Housing: passo 4, immagine 2 di 2
    • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
    Chiedi a FixBot
    Aggiungi Commento
  5. Enabot EBO SE Camera Replacement: passo 5, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 5, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 5, immagine 3 di 3
    • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
    • Keep the Micro SD Card in a safe spot for later.
    Chiedi a FixBot
    Aggiungi Commento
  6. Enabot EBO SE Camera Replacement: passo 6, immagine 1 di 2 Enabot EBO SE Camera Replacement: passo 6, immagine 2 di 2
    • Place the iFixit opening tool inside the Micro SD slot.
    • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Enabot EBO SE Camera Replacement: passo 7, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 7, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 7, immagine 3 di 3
    • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
    • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
    Chiedi a FixBot
    Aggiungi Commento
  8. Enabot EBO SE Camera Replacement: passo 8, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 8, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 8, immagine 3 di 3
    • There are two black and red wire connectors attached to the upper and lower housing.
    • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
    Chiedi a FixBot
    Aggiungi Commento
  9. Enabot EBO SE Camera Replacement, Motherboard: passo 9, immagine 1 di 2 Enabot EBO SE Camera Replacement, Motherboard: passo 9, immagine 2 di 2
    • Use the iFixit opening tool to unlock the side gray tab and free the orange & black ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  10. Enabot EBO SE Camera Replacement: passo 10, immagine 1 di 2 Enabot EBO SE Camera Replacement: passo 10, immagine 2 di 2
    • Use the iFixit opening tool to unlock the middle gray tab and free the orange & black ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  11. Enabot EBO SE Camera Replacement: passo 11, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 11, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 11, immagine 3 di 3
    • Select one of the release tabs on the edge of the upper casing that holds the motherboard in place.
    • Place one finger in between the motherboard and the upper casing.
    • Pull the release tab back while lifting the motherboard with your other finger to "pop" the motherboard out of the casing.
    Chiedi a FixBot
    Aggiungi Commento
  12. Enabot EBO SE Camera Replacement: passo 12, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 12, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 12, immagine 3 di 3
    • Use the ifixit opening tool to disconnect the blue & white ribbon cable.
    • Gently pull the blue & white ribbon cable out of the gray connector tab.
    Chiedi a FixBot
    Aggiungi Commento
  13. Enabot EBO SE Camera Replacement, Camera: passo 13, immagine 1 di 3 Enabot EBO SE Camera Replacement, Camera: passo 13, immagine 2 di 3 Enabot EBO SE Camera Replacement, Camera: passo 13, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove all five 7.4 mm screws from the upper casing.
    Chiedi a FixBot
    Aggiungi Commento
  14. Enabot EBO SE Camera Replacement: passo 14, immagine 1 di 2 Enabot EBO SE Camera Replacement: passo 14, immagine 2 di 2
    • Place your fingers in the space between the black casing and white lid.
    • Pull black casing towards you to separate the two parts.
    Chiedi a FixBot
    Aggiungi Commento
  15. Enabot EBO SE Camera Replacement: passo 15, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 15, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 15, immagine 3 di 3
    • Remove the two 6 mm Phillips #00 screws on either side of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  16. Enabot EBO SE Camera Replacement: passo 16, immagine 1 di 3 Enabot EBO SE Camera Replacement: passo 16, immagine 2 di 3 Enabot EBO SE Camera Replacement: passo 16, immagine 3 di 3
    • Gently remove the camera until it comes out of the casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Oscar Parra
Membro da: 02/16/24
109 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 47
Tutti i Tempi: 623
