Salta al contenuto principale
Eightarc Fusion USB Cable Replacement
Cosa ti serve
  1. Eightarc Fusion USB Cable Replacement, USB Cable: passo 1, immagine 1 di 2 Eightarc Fusion USB Cable Replacement, USB Cable: passo 1, immagine 2 di 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Chiedi a FixBot
    Aggiungi Commento
  2. Eightarc Fusion USB Cable Replacement: passo 2, immagine 1 di 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Eightarc Fusion USB Cable Replacement: passo 3, immagine 1 di 1
    • With flap unlatched, gently bend the flap and pull slightly to get the pegs out of the socket
    • Be sure to be gentle and not snap the plastic flap in half.
    Chiedi a FixBot
    Aggiungi Commento
  4. Eightarc Fusion USB Cable Replacement: passo 4, immagine 1 di 1
    • Slide USB cable up from the plastic barrier casing.
    Chiedi a FixBot
    Aggiungi Commento
  5. Eightarc Fusion USB Cable Replacement: passo 5, immagine 1 di 3 Eightarc Fusion USB Cable Replacement: passo 5, immagine 2 di 3 Eightarc Fusion USB Cable Replacement: passo 5, immagine 3 di 3
    • The USB cord is connected to the logic board by a plastic plug with five wires.
    • Gently pull up and wiggle the white plastic end attached to the wires out of the mother board.
    • The white casing on top pulls off from its counterpart on the logic board. Do not take off the bottom part of the white fixture from the logic board.
    • Remove USB cable from device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Dana
Membro da: 02/01/15
141 Reputazione
Una guida realizzata
Cal Poly, Team 17-35, Amido Winter 2015 Membro di Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Membri
5 guide realizzate
1Commento della guida
Where do I get the USB wire?
desmond.bouey1 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 39
Tutti i Tempi: 1,238
