Salta al contenuto principale
Eightarc Fusion Joystick Replacement
Cosa ti serve
  1. Eightarc Fusion Joystick Replacement, Joystick: passo 1, immagine 1 di 2 Eightarc Fusion Joystick Replacement, Joystick: passo 1, immagine 2 di 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Chiedi a FixBot
    Aggiungi Commento
  2. Eightarc Fusion Joystick Replacement: passo 2, immagine 1 di 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Eightarc Fusion Joystick Replacement: passo 3, immagine 1 di 2 Eightarc Fusion Joystick Replacement: passo 3, immagine 2 di 2
    • Use the large plastic opening tool to softly pry the lip on the white 5 pin connector to relieve pressure while pulling the 5 pin connector.
    • Remove the white connector from the microswitch assembly.
    Chiedi a FixBot
    Aggiungi Commento
  4. Eightarc Fusion Joystick Replacement: passo 4, immagine 1 di 2 Eightarc Fusion Joystick Replacement: passo 4, immagine 2 di 2
    • Insert a #4 Flat Head screwdriver into the shaft of the joystick and grasp the ball topper with your other hand.
    • Turn the flat head screwdriver counter clockwise for a quarter turn while tightly holding the ball topper.
    • The ball topper should now be loose enough to unscrew by hand.
    • Set aside the shaft cover, dust cover, and ball topper.
    Chiedi a FixBot
    Aggiungi Commento
  5. Eightarc Fusion Joystick Replacement: passo 5, immagine 1 di 2 Eightarc Fusion Joystick Replacement: passo 5, immagine 2 di 2
    • Remove the four 8.35 mm screws from the mounting plate of the joystick using a Phillips Head #2 screwdriver.
    • Remove the joystick assembly from the controller.
    Chiedi a FixBot
    Aggiungi Commento
  6. Eightarc Fusion Joystick Replacement: passo 6, immagine 1 di 3 Eightarc Fusion Joystick Replacement: passo 6, immagine 2 di 3 Eightarc Fusion Joystick Replacement: passo 6, immagine 3 di 3
    • Place joystick assembly on a hard, flat surface.
    • Gently press on the four black tabs on each side of the assembly.
    • With the tabs depressed, lift the clear restrictor plate from the assembly.
    Chiedi a FixBot
    Aggiungi Commento
  7. Eightarc Fusion Joystick Replacement: passo 7, immagine 1 di 1
    • Remove the switch housing from the assembly by lifting straight up.
    • The joystick assembly is now ready to be replaced or cleaned.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Austin
Membro da: 01/28/15
245 Reputazione
2 guide realizzate
Cal Poly, Team 17-35, Amido Winter 2015 Membro di Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 9
Ultimi 30 giorni: 58
Tutti i Tempi: 1,368
