Salta al contenuto principale
Eightarc Fusion Button Replacement
Cosa ti serve
  1. Eightarc Fusion Button Replacement, Buttons: passo 1, immagine 1 di 1
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface, or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Chiedi a FixBot
    Aggiungi Commento
  2. Eightarc Fusion Button Replacement: passo 2, immagine 1 di 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Eightarc Fusion Button Replacement: passo 3, immagine 1 di 1
    • Remove the clear rubber casing around the wire connector by lifting the casing up and moving it up along the wire.
    • Repeat for second clear rubber casing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Eightarc Fusion Button Replacement: passo 4, immagine 1 di 2 Eightarc Fusion Button Replacement: passo 4, immagine 2 di 2
    • Gently grasp and lift up on the metal section of the wire to remove the wire from the button connector.
    • A slight wiggling motion might help remove the wire from the connector.
    • Make sure to keep track of which wires go to what button slot location.
    Chiedi a FixBot
    Aggiungi Commento
  5. Eightarc Fusion Button Replacement: passo 5, immagine 1 di 2 Eightarc Fusion Button Replacement: passo 5, immagine 2 di 2
    • Gently depress the two plastic tabs on both of the sides of the button casing.
    • The plastic tabs on the buttons are extremely fragile, handle with care.
    • Slightly push the button down, out of the controller until it slides out.
    • During re-assembly, make sure the button tabs align with the slots in the casing when inserting the button back in.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Austin
Membro da: 01/28/15
245 Reputazione
2 guide realizzate
Cal Poly, Team 17-35, Amido Winter 2015 Membro di Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 1,134
