Salta al contenuto principale
EBK340 Powerhead Replacement
Cosa ti serve
  1. EBK340  Powerhead  Replacement, Remove Outer Cover: passo 1, immagine 1 di 1
    • Position the device so brushes are upwards and visible
    • Unscrew the 6 outer screws. 2 on the edge of the brush crevice, and 4 nearer to the wheels.
    • Turn over the device.
    • Pull the cover off gently.
    Chiedi a FixBot
    Aggiungi Commento
  2. EBK340  Powerhead  Replacement, Remove Inner Cover: passo 2, immagine 1 di 1
    • Unscrew the 2 screws indicated, one visible, the other within a deep hole
    • Gently pull off the cover. Careful not to torque the plastic teeth shown in orange.
    Chiedi a FixBot
    Aggiungi Commento
  3. EBK340  Powerhead  Replacement, Replace Neck Joint: passo 3, immagine 1 di 2 EBK340  Powerhead  Replacement, Replace Neck Joint: passo 3, immagine 2 di 2
    • Gently lift the two LED lights upwards and away for the moment.
    • Gently lift out the defective neck joint.
    • Slide in the replacement joint.
    • Replace the lights into the molded corners that hold their board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
FolsomMaids Office
Membro da: 10/09/19
167 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 294
