Salta al contenuto principale
Dyson DC39 Origin Cyclone Filter Replacement
Cosa ti serve
    1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: passo 1, immagine 1 di 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: passo 1, immagine 2 di 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: passo 1, immagine 3 di 3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: passo 2, immagine 1 di 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: passo 2, immagine 2 di 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: passo 2, immagine 3 di 3
      • Remove the purple pre-filter by pulling it up and out of the bin.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: passo 3, immagine 1 di 2 Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: passo 3, immagine 2 di 2
      • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dyson DC39 Origin Cyclone Filter Replacement: passo 4, immagine 1 di 1
      • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
      • The grey button can only be pressed after the bottom section is open.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dyson DC39 Origin Cyclone Filter Replacement: passo 5, immagine 1 di 3 Dyson DC39 Origin Cyclone Filter Replacement: passo 5, immagine 2 di 3 Dyson DC39 Origin Cyclone Filter Replacement: passo 5, immagine 3 di 3
      • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
      • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Sam Nelson
Membro da: 04/26/17
167 Reputazione
Una guida realizzata
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro di Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 69
Tutti i Tempi: 4,082
