Salta al contenuto principale
Dyson DC39 Origin Replacement
Cosa ti serve
    1. Dyson DC39 Origin  Replacement, Bin: passo 1, immagine 1 di 3 Dyson DC39 Origin  Replacement, Bin: passo 1, immagine 2 di 3 Dyson DC39 Origin  Replacement, Bin: passo 1, immagine 3 di 3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dyson DC39 Origin  Replacement, Steering Assembly: passo 2, immagine 1 di 3 Dyson DC39 Origin  Replacement, Steering Assembly: passo 2, immagine 2 di 3 Dyson DC39 Origin  Replacement, Steering Assembly: passo 2, immagine 3 di 3
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dyson DC39 Origin  Replacement: passo 3, immagine 1 di 3 Dyson DC39 Origin  Replacement: passo 3, immagine 2 di 3 Dyson DC39 Origin  Replacement: passo 3, immagine 3 di 3
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dyson DC39 Origin  Replacement, Inlet Hose: passo 4, immagine 1 di 2 Dyson DC39 Origin  Replacement, Inlet Hose: passo 4, immagine 2 di 2
      • Remove the two 17.8 mm Phillips #2 screws located in the top of the inlet hose bracket.
      • Remove the two 13.7 mm Torx 8 screws located at the opposite end of the inlet hose.
      • The Torx 8 screws are located at an odd angle. Be sure the screwdriver is secure to prevent stripping the screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dyson DC39 Origin  Replacement: passo 5, immagine 1 di 2 Dyson DC39 Origin  Replacement: passo 5, immagine 2 di 2
      • Pull the inlet hose straight up from the steering assembly.
      • The inlet hose 'snaps' out of its position, so you may have to apply a little extra force while pulling.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro di Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Membri
15 guide realizzate
1Commento della guida
Really clear instructions - thank you
collette - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 47
Tutti i Tempi: 4,826
