Salta al contenuto principale
Dremel 8220 Motor Replacement
Cosa ti serve
    1. Dremel 8220 Motor Replacement, Motor: passo 1, immagine 1 di 1
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dremel 8220 Motor Replacement: passo 2, immagine 1 di 1
      • Remove the ring located around the speed selector switch by pulling apart on either side. (This should require very minimal force.)
      Chiedi a FixBot
      Aggiungi Commento
    3. Dremel 8220 Motor Replacement: passo 3, immagine 1 di 1
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      Chiedi a FixBot
      Aggiungi Commento
    4. Dremel 8220 Motor Replacement: passo 4, immagine 1 di 1
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a spudger.
      Chiedi a FixBot
      Aggiungi Commento
    5. Dremel 8220 Motor Replacement: passo 5, immagine 1 di 3 Dremel 8220 Motor Replacement: passo 5, immagine 2 di 3 Dremel 8220 Motor Replacement: passo 5, immagine 3 di 3
      • Remove five 10.5 mm Torx T9 screws.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      Chiedi a FixBot
      Aggiungi Commento
    6. Dremel 8220 Motor Replacement: passo 6, immagine 1 di 2 Dremel 8220 Motor Replacement: passo 6, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Remove broken motor. Lift out the motor until you can see the wires that connect to it.
      • Remove the clips where the wires connect with the motor. This can be done with your fingers of a pair of tweezers.
      • You should then be able to reconnect a new motor and reassemble the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
3Commenti sulla guida
Have you ever taken apart the motor? If so how?
Micky Ashey - Rispondi Condividi
Is there polarity correctness of the motor connections?
cal yoshikawa - Rispondi Condividi
Yes cal, the +ve (red) wire connects to the spade marked with a red dot.
qedelectrics - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 57
Tutti i Tempi: 5,816
