Salta al contenuto principale
Dremel 8220 Gear Lock Button Replacement
Cosa ti serve
    1. Dremel 8220 Gear Lock Button Replacement, Gear Lock Button: passo 1, immagine 1 di 1
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dremel 8220 Gear Lock Button Replacement: passo 2, immagine 1 di 1
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dremel 8220 Gear Lock Button Replacement: passo 3, immagine 1 di 1
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      Chiedi a FixBot
      Aggiungi Commento
    4. Dremel 8220 Gear Lock Button Replacement: passo 4, immagine 1 di 1
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    5. Dremel 8220 Gear Lock Button Replacement: passo 5, immagine 1 di 3 Dremel 8220 Gear Lock Button Replacement: passo 5, immagine 2 di 3 Dremel 8220 Gear Lock Button Replacement: passo 5, immagine 3 di 3
      • Remove the 5 torx screws using a t9 screwdriver head.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      Chiedi a FixBot
      Aggiungi Commento
    6. Dremel 8220 Gear Lock Button Replacement: passo 6, immagine 1 di 1
      • Remove the faulty gear lock button. It should come out of the device easily with no force needed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
3Commenti sulla guida
I’m assuming the issue I have is a faulty gear-lock button (that, or the locking gear that it restricts when depressed). If so, did you find a replacement button from the manufacturer? In my experience, they rarely offer repair parts themselves.
Robert - Rispondi Condividi
I also don’t understand why there was a flag claiming that this should be broken into separate guides. People aren’t THAT stupid, I hope.
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 40
Tutti i Tempi: 1,399
