Salta al contenuto principale
Dragon Touch Y88X Plus Battery Replacement
Cosa ti serve
  1. Dragon Touch Y88X Plus Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Battery Replacement: passo 2, immagine 1 di 2 Dragon Touch Y88X Plus Battery Replacement: passo 2, immagine 2 di 2
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
    • Carefully peel the old battery from the adhesive using your iFixit pry tool.
    • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
  3. Dragon Touch Y88X Plus Battery Replacement: passo 3, immagine 1 di 2 Dragon Touch Y88X Plus Battery Replacement: passo 3, immagine 2 di 2
    • Use a soldering iron to disconnect each connector individually from the motherboard.
  4. Dragon Touch Y88X Plus Battery Replacement: passo 4, immagine 1 di 1
    • Remove any adhesive from the battery.
    • Remove the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Bavly Aziz
Membro da: 10/30/23
195 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Membro di UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 99
