Salta al contenuto principale
Disassembling the Teac DC-D2831
Cosa ti serve
    1. Disassembling the Teac DC-D2831, Disassembling the Teac DC-D2831: passo 1, immagine 1 di 1
      • Make sure the device is turned off and unplugged. This will eliminate the danger of getting electrocuted while repairing the device or damaging components.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling the Teac DC-D2831: passo 2, immagine 1 di 2 Disassembling the Teac DC-D2831: passo 2, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Lift the lid to get to the turntable.
      • Using the appropriate tools (needle-nose pliers, tweezers, screwdriver, etc.), remove the snap ring from the center of the turntable. The snap-ring is the small metal ring around the axel of the turntable.
      • The snap-ring is hard to remove so be patient and don't be afraid to use some force.
      • Feel free to use whatever tool(s) that will remove the snap-ring. The above list of tools are just a suggestions.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling the Teac DC-D2831: passo 3, immagine 1 di 2 Disassembling the Teac DC-D2831: passo 3, immagine 2 di 2
      • Gently lift the turntable from the rest of the device.
      • If the device has a faulty belt, see the belt repair guide here: Belt Repair Guide
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling the Teac DC-D2831: passo 4, immagine 1 di 1
      • Remove the screws on the side of the device using a Phillips #2 screwdriver.
      • When removing the screws, take note of which screws go where.
      • 27.0mm
      • 19.8mm
      • 12.0mm
      Chiedi a FixBot
      Aggiungi Commento
    5. Disassembling the Teac DC-D2831: passo 5, immagine 1 di 2 Disassembling the Teac DC-D2831: passo 5, immagine 2 di 2
      • Lift the base that the turntable was resting on from the rest of the device.
      • Remove the base slowly so to not sever the connection with the wire attached from the base to the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    6. Disassembling the Teac DC-D2831: passo 6, immagine 1 di 1
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 2-61, Propen Fall 2012 Membro di Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Membri
15 guide realizzate
3Commenti sulla guida
How to remove lid from CD-D2831
jfranklinhamm - Rispondi Condividi
So radio sound and tape work and sound is great. However when turn table is on the sound is low only on that component any help would be greatly appreciated
Joanna Chavez - Rispondi Condividi
Does anyone know how to fix the cd player?
Mine won't open when the button is pressed. All other features work, Radio, LP player and Tape decks.
There are no disks stuck in the tray, I checked.
Thxs
Boxterfan - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 34
Tutti i Tempi: 5,473
