Salta al contenuto principale
Disassembling VTech MobiGo Touch Learning System Keyboard
Cosa ti serve
  1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: passo 1, immagine 1 di 1
    • Remove the battery covers and the four batteries.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 2, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 2, immagine 2 di 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 3, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 3, immagine 2 di 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
    Chiedi a FixBot
    Aggiungi Commento
  4. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: passo 4, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: passo 4, immagine 2 di 2
    • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
    • Use light pressure to prevent damage to the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  5. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 5, immagine 1 di 1
    • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
    • Once the screw is removed, remove the blue plastic cover.
    Chiedi a FixBot
    Aggiungi Commento
  6. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 6, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 6, immagine 2 di 2
    • Remove the two 4.0 mm Philips J0 screws located on the orange case.
    • Use gentle force to prevent stripping of screws.
    Chiedi a FixBot
    Aggiungi Commento
  7. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, immagine 1 di 3 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, immagine 2 di 3 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, immagine 3 di 3
    • Remove the two "L" shaped brackets located on both sides of the device.
    • Use the magnetic mat to store these brackets.
    Chiedi a FixBot
    Aggiungi Commento
  8. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 8, immagine 1 di 1
    • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
    Chiedi a FixBot
    Aggiungi Commento
  9. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 9, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 9, immagine 2 di 2
    • Gently lift the circuit board from the case using a plastic opening tool.
    • Make sure to use a plastic opening tool for this step.
    Chiedi a FixBot
    Aggiungi Commento
  10. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 10, immagine 1 di 1
    • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
    • Keep the circuit board out of the way to avoid damaging it.
    Chiedi a FixBot
    Aggiungi Commento
  11. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 11, immagine 1 di 1
    • Slowly remove the keyboard panel.
    • Use a spudger if necessary.
    • The keys will fall out once the keyboard panel is removed.
    • Remove all of the keys and set them aside with the keyboard panel.
    Chiedi a FixBot
    Aggiungi Commento
  12. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 12, immagine 1 di 1
    • Gently remove the keyboard circuit board with a plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
RBansil
Membro da: 08/27/15
221 Reputazione
2 guide realizzate
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro di USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membri
17 guide realizzate
1Commento della guida
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 40
Tutti i Tempi: 2,419
