Salta al contenuto principale
Disassembling Nokia 2366i Front Display
Cosa ti serve
  1. Disassembling Nokia 2366i Front Display, Battery: passo 1, immagine 1 di 2 Disassembling Nokia 2366i Front Display, Battery: passo 1, immagine 2 di 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling Nokia 2366i Front Display: passo 2, immagine 1 di 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling Nokia 2366i Front Display: passo 3, immagine 1 di 3 Disassembling Nokia 2366i Front Display: passo 3, immagine 2 di 3 Disassembling Nokia 2366i Front Display: passo 3, immagine 3 di 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
    Chiedi a FixBot
    Aggiungi Commento
  4. Disassembling Nokia 2366i Front Display, Front Cover: passo 4, immagine 1 di 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
    Chiedi a FixBot
    Aggiungi Commento
  5. Disassembling Nokia 2366i Front Display: passo 5, immagine 1 di 2 Disassembling Nokia 2366i Front Display: passo 5, immagine 2 di 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
    Chiedi a FixBot
    Aggiungi Commento
  6. Disassembling Nokia 2366i Front Display: passo 6, immagine 1 di 2 Disassembling Nokia 2366i Front Display: passo 6, immagine 2 di 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
    Chiedi a FixBot
    Aggiungi Commento
  7. Disassembling Nokia 2366i Front Display, Main Display: passo 7, immagine 1 di 2 Disassembling Nokia 2366i Front Display, Main Display: passo 7, immagine 2 di 2
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. Disassembling Nokia 2366i Front Display: passo 8, immagine 1 di 2 Disassembling Nokia 2366i Front Display: passo 8, immagine 2 di 2
    • Using the spudger, disconnect the green display cable.
    Chiedi a FixBot
    Aggiungi Commento
  9. Disassembling Nokia 2366i Front Display: passo 9, immagine 1 di 3 Disassembling Nokia 2366i Front Display: passo 9, immagine 2 di 3 Disassembling Nokia 2366i Front Display: passo 9, immagine 3 di 3
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
    Chiedi a FixBot
    Aggiungi Commento
  10. Disassembling Nokia 2366i Front Display, Front Display: passo 10, immagine 1 di 3 Disassembling Nokia 2366i Front Display, Front Display: passo 10, immagine 2 di 3 Disassembling Nokia 2366i Front Display, Front Display: passo 10, immagine 3 di 3
    • Fold the metal casing back over.
    • Disconnect the orange front display data cable with the spudger.
    • Hold the phone so that the antenna is facing towards you.
    • Lift up and flip over the metal casing.
    Chiedi a FixBot
    Aggiungi Commento
  11. Disassembling Nokia 2366i Front Display: passo 11, immagine 1 di 1
    • Using your fingers, remove the front display.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 1-14, Amido Winter 2011 Membro di Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Membri
28 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 37
Tutti i Tempi: 1,320
