Salta al contenuto principale
Disassembling Netatmo Outdoor Camera Main Unit
Cosa ti serve
  1. Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: passo 1, immagine 1 di 2 Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: passo 1, immagine 2 di 2
    • Remove the plate at the bottom of the camera by inserting a screwdriver in the slot, and bending while pulling.
    • The panel will lift up and can be removed.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling Netatmo Outdoor Camera Main Unit: passo 2, immagine 1 di 2 Disassembling Netatmo Outdoor Camera Main Unit: passo 2, immagine 2 di 2
    • Insert a flathead screwdriver into each hole at the front of the camera and push the two tabs to the centre and forwards.
    • It's hard to see, but you need the triangular part at the front, rather than what appears to be a tab at the back.
    • Pushing towards the centre allows the lens cover to come off. These can be done one at a time.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling Netatmo Outdoor Camera Main Unit: passo 3, immagine 1 di 2 Disassembling Netatmo Outdoor Camera Main Unit: passo 3, immagine 2 di 2
    • Remove the six 2.5mm hex screws using a long Allen key.
    • One screw has an earthing ring wire. Don't forget this when reassembling.
    Chiedi a FixBot
    Aggiungi Commento
  4. Disassembling Netatmo Outdoor Camera Main Unit: passo 4, immagine 1 di 2 Disassembling Netatmo Outdoor Camera Main Unit: passo 4, immagine 2 di 2
    • Separate the two pieces by pulling slightly on the lower module.
    • Pull the metal housing forward.
    • Pushing the light from the inside can help in removing the shell.
    Chiedi a FixBot
    Aggiungi Commento
  5. Disassembling Netatmo Outdoor Camera Main Unit: passo 5, immagine 1 di 1
    • Using a 1.5mm hex screwdriver remove the four screws holding on the camera module.
    Chiedi a FixBot
    Aggiungi Commento
  6. Disassembling Netatmo Outdoor Camera Main Unit: passo 6, immagine 1 di 2 Disassembling Netatmo Outdoor Camera Main Unit: passo 6, immagine 2 di 2
    • From this point the housing can be worked up and diagonally to reveal the circuit board, and ribbon cable.
    • Be careful with both the camera module ribbon and the one for the LED lights (which cannot be removed).
    • Do not slide the circuit board within the heatsink otherwise you risk ripping the LED ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 38
Ultimi 30 giorni: 103
Tutti i Tempi: 1,160
