Salta al contenuto principale
Disassembling Nerf Recon CS-6 Shell
Cosa ti serve
  1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: passo 1, immagine 1 di 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: passo 2, immagine 1 di 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: passo 3, immagine 1 di 2 Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: passo 3, immagine 2 di 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
    Chiedi a FixBot
    Aggiungi Commento
  4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: passo 4, immagine 1 di 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
    Chiedi a FixBot
    Aggiungi Commento
  5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: passo 5, immagine 1 di 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
    Chiedi a FixBot
    Aggiungi Commento
  6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: passo 6, immagine 1 di 2 Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: passo 6, immagine 2 di 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Baylor, Team 8-14, Williams Fall 2014 Membro di Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Membri
6 guide realizzate
2Commenti sulla guida
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - Rispondi Condividi
very useful, thanks!
Sebastian Isaacs - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 48
Tutti i Tempi: 12,881
