Salta al contenuto principale
Disassembling IBM WorkPad c3 LCD
Cosa ti serve
  1. Disassembling IBM WorkPad c3 LCD, Back Case: passo 1, immagine 1 di 2 Disassembling IBM WorkPad c3 LCD, Back Case: passo 1, immagine 2 di 2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling IBM WorkPad c3 LCD: passo 2, immagine 1 di 1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling IBM WorkPad c3 LCD: passo 3, immagine 1 di 2 Disassembling IBM WorkPad c3 LCD: passo 3, immagine 2 di 2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    Chiedi a FixBot
    Aggiungi Commento
  4. Disassembling IBM WorkPad c3 LCD, Front Case: passo 4, immagine 1 di 2 Disassembling IBM WorkPad c3 LCD, Front Case: passo 4, immagine 2 di 2
    • Turn the device over, so that the screen is laying on a flat surface.
    Chiedi a FixBot
    Aggiungi Commento
  5. Disassembling IBM WorkPad c3 LCD: passo 5, immagine 1 di 3 Disassembling IBM WorkPad c3 LCD: passo 5, immagine 2 di 3 Disassembling IBM WorkPad c3 LCD: passo 5, immagine 3 di 3
    • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
    • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
    • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
    Chiedi a FixBot
    Aggiungi Commento
  6. Disassembling IBM WorkPad c3 LCD: passo 6, immagine 1 di 2 Disassembling IBM WorkPad c3 LCD: passo 6, immagine 2 di 2
    • The device will be extremely hot. Use a towel or oven mitt to grab it.
    • Using the Plastic Opening Tools, take the front of the case off.
    • If the case is difficult to remove, try repeating step 2.
    • The power button at the top of the device will be loose once the front part of the case is removed.
    Chiedi a FixBot
    Aggiungi Commento
  7. Disassembling IBM WorkPad c3 LCD, Battery: passo 7, immagine 1 di 1
    • Remove the yellow tape that is covering the battery connector
    Chiedi a FixBot
    Aggiungi Commento
  8. Disassembling IBM WorkPad c3 LCD: passo 8, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Using the tweezers, carefully disconnect the battery cable from the port
    Chiedi a FixBot
    Aggiungi Commento
  9. Disassembling IBM WorkPad c3 LCD: passo 9, immagine 1 di 2 Disassembling IBM WorkPad c3 LCD: passo 9, immagine 2 di 2
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
    Chiedi a FixBot
    Aggiungi Commento
  10. Disassembling IBM WorkPad c3 LCD, LCD: passo 10, immagine 1 di 2 Disassembling IBM WorkPad c3 LCD, LCD: passo 10, immagine 2 di 2
    • Using the spudger lift the tabs holding the LCD/Digitizer combo cables to the WorkPad.
    Chiedi a FixBot
    Aggiungi Commento
  11. Disassembling IBM WorkPad c3 LCD: passo 11, immagine 1 di 2 Disassembling IBM WorkPad c3 LCD: passo 11, immagine 2 di 2
    • Using your thumb, press down gently on the back of the LCD.
    • The LCD will disconnect and fall out of the case, so be sure to have your hand waiting for it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 21-35, Regan Fall 2010 Membro di Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 36
Tutti i Tempi: 2,323
