Salta al contenuto principale
Disassembling IBM ThinkPad A30 Motherboard
Cosa ti serve
    1. Disassembling IBM ThinkPad A30 Motherboard, Battery: passo 1, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard, Battery: passo 1, immagine 2 di 2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: passo 2, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: passo 2, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: passo 2, immagine 3 di 3
      • Remove the highlighted screw with a Phillips #1 screwdriver.
      • Pull the hard drive out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, CD Drive: passo 3, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard, CD Drive: passo 3, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard, CD Drive: passo 3, immagine 3 di 3
      • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
      • Slide the switch to the right. A black plastic tab will pop out.
      • Pull the plastic tab to expose the CD drive.
      • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling IBM ThinkPad A30 Motherboard: passo 4, immagine 1 di 1
      • Carefully pull the CD drive out from the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: passo 5, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: passo 5, immagine 2 di 2
      • Hold the Thinkpad as the picture shows.
      • There is a switch located just above and to the right of the drive.
      • Slide the switch to the right. A small, black tab will pop out.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling IBM ThinkPad A30 Motherboard: passo 6, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 6, immagine 2 di 2
      • Pull the small black tab away from the computer to access the drive.
      • Gently pull the drive out from the laptop.
      • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, Upper Case: passo 7, immagine 1 di 1
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling IBM ThinkPad A30 Motherboard: passo 8, immagine 1 di 1
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling IBM ThinkPad A30 Motherboard: passo 9, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 9, immagine 2 di 2
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling IBM ThinkPad A30 Motherboard: passo 10, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 10, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 10, immagine 3 di 3
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
      Chiedi a FixBot
      Aggiungi Commento
    5. Disassembling IBM ThinkPad A30 Motherboard: passo 11, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 11, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 11, immagine 3 di 3
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
      Chiedi a FixBot
      Aggiungi Commento
    6. Disassembling IBM ThinkPad A30 Motherboard: passo 12, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 12, immagine 2 di 2
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
      Chiedi a FixBot
      Aggiungi Commento
    7. Disassembling IBM ThinkPad A30 Motherboard: passo 13, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 13, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 13, immagine 3 di 3
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, Display Assembly: passo 14, immagine 1 di 1
      • Remove the 5.6mm screw that holds the LCD to the upper case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling IBM ThinkPad A30 Motherboard: passo 15, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 15, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 15, immagine 3 di 3
      • Remove the 5.6mm screw on the left side of the three-pronged connector.
      • Remove the other two 16.7mm screws.
      • Lift and remove connector.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling IBM ThinkPad A30 Motherboard: passo 16, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 16, immagine 2 di 2
      • Pull out the white tab connecting the LCD to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling IBM ThinkPad A30 Motherboard: passo 17, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 17, immagine 2 di 2
      • Turn the laptop so that the back is facing you.
      • Remove the four 5.6mm long screws.
      Chiedi a FixBot
      Aggiungi Commento
    5. Disassembling IBM ThinkPad A30 Motherboard: passo 18, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 18, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 18, immagine 3 di 3
      • Place the laptop so that the LCD is facing you again.
      • Gently lift the LCD monitor up and out.
      • Remove the black plastic tab.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, Fan: passo 19, immagine 1 di 1
      • Remove the following screws from the fan retention bracket:
      • Single 5.6 mm screw.
      • Three 16.1 mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling IBM ThinkPad A30 Motherboard: passo 20, immagine 1 di 1
      • Lift the heatsink bracket up.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling IBM ThinkPad A30 Motherboard: passo 21, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 21, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 21, immagine 3 di 3
      • Be careful not to pull too hard. There is a cable attached to the fan.
      • Lift the fan/heatsink assembly up.
      • Locate the fan power cable and pull upwards near the connector.
      • Remove the fan/heatsink assembly.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, CPU: passo 22, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard, CPU: passo 22, immagine 2 di 2
      • Use a flathead to turn the screw 180 degrees.
      • Remove the CPU by lifting it upwards.
      • If the CPU is reusable, place it in an antistatic bag and away from moisture.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling IBM ThinkPad A30 Motherboard, Motherboard: passo 23, immagine 1 di 1
      • Locate the floppy drive bay.
      • Remove the four 5.6mm screws.
      • Remove the 16mm screw.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling IBM ThinkPad A30 Motherboard: passo 24, immagine 1 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 24, immagine 2 di 3 Disassembling IBM ThinkPad A30 Motherboard: passo 24, immagine 3 di 3
      • Turn the laptop over so that the battery is towards you.
      • Locate the modem and ethernet card bay.
      • Remove the two 5.3mm cover screws.
      • Gently lift the cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling IBM ThinkPad A30 Motherboard: passo 25, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 25, immagine 2 di 2
      • Remove the four 9.1mm screws attached to the modem and ethernet cards.
      • When lifting the cards, be careful not to rip out the cables!
      • Gently lift the modem and ethernet cards.
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling IBM ThinkPad A30 Motherboard: passo 26, immagine 1 di 1
      • Locate the hard drive slot.
      • Remove the 8.8mm screw with a Phillips #0 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    5. Disassembling IBM ThinkPad A30 Motherboard: passo 27, immagine 1 di 1
      • Turn the laptop over again and orient it as shown.
      • Lift the left side of the floppy disk bay and and pull it out.
      • The black lever will pop out.
      Chiedi a FixBot
      Aggiungi Commento
    6. Disassembling IBM ThinkPad A30 Motherboard: passo 28, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 28, immagine 2 di 2
      • Locate the CD Drive Bay
      • Remove the three 5.6mm screws.
      • Lift the right side and pull the CD drive bay out.
      Chiedi a FixBot
      Aggiungi Commento
    7. Disassembling IBM ThinkPad A30 Motherboard: passo 29, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 29, immagine 2 di 2
      • Once the CD drive bay is removed, locate the speaker data and power cables.
      • Remove the cables from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    8. Disassembling IBM ThinkPad A30 Motherboard: passo 30, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 30, immagine 2 di 2
      • Locate the expansion bay.
      • Lift and remove the expansion bay.
      Chiedi a FixBot
      Aggiungi Commento
    9. Disassembling IBM ThinkPad A30 Motherboard: passo 31, immagine 1 di 1
      • Rotate the laptop so that the back ports are facing you.
      Chiedi a FixBot
      Aggiungi Commento
    10. Disassembling IBM ThinkPad A30 Motherboard: passo 32, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 32, immagine 2 di 2
      • Remove the three 5.8mm screws with a Phillips #0 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    11. Disassembling IBM ThinkPad A30 Motherboard: passo 33, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 33, immagine 2 di 2
      • Remove the six 11mm nuts with a wrench.
      • Pliers can be used, but are not recommended.
      Chiedi a FixBot
      Aggiungi Commento
    12. Disassembling IBM ThinkPad A30 Motherboard: passo 34, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 34, immagine 2 di 2
      • Rotate the laptop to its original position.
      • Remove the 5.6mm screw located on the upper right corner of the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    13. Disassembling IBM ThinkPad A30 Motherboard: passo 35, immagine 1 di 2 Disassembling IBM ThinkPad A30 Motherboard: passo 35, immagine 2 di 2
      • The wireless and bluetooth cards are connected to the motherboard!
      • Pull out the motherboard towards you carefully.
      • Place the motherboard somewhere dry and clean.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Alan
Membro da: 10/07/10
380 Reputazione
6 guide realizzate
Cal Poly, Team 4-44, Amido Fall 2010 Membro di Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membri
26 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 24
Tutti i Tempi: 9,095
