Salta al contenuto principale
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: passo 1, immagine 1 di 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: passo 1, immagine 2 di 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: passo 2, immagine 1 di 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: passo 2, immagine 2 di 2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: passo 3, immagine 1 di 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive: passo 3, immagine 2 di 2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
Membro da: 10/06/10
162 Reputazione
7 guide realizzate
Cal Poly, Team 4-44, Amido Fall 2010 Membro di Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membri
26 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 53
Tutti i Tempi: 3,211
