Salta al contenuto principale
Disassembling Flip Video USB Port
Cosa ti serve
    1. Disassembling Flip Video USB Port, Outer Shell: passo 1, immagine 1 di 2 Disassembling Flip Video USB Port, Outer Shell: passo 1, immagine 2 di 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling Flip Video USB Port: passo 2, immagine 1 di 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling Flip Video USB Port: passo 3, immagine 1 di 2 Disassembling Flip Video USB Port: passo 3, immagine 2 di 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling Flip Video USB Port: passo 4, immagine 1 di 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Chiedi a FixBot
      Aggiungi Commento
    5. Disassembling Flip Video USB Port: passo 5, immagine 1 di 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling Flip Video USB Port, Circuit Board: passo 6, immagine 1 di 1
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling Flip Video USB Port: passo 7, immagine 1 di 1
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling Flip Video USB Port: passo 8, immagine 1 di 1
      • Disconnect the USB port cable from the back side of the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling Flip Video USB Port: passo 9, immagine 1 di 1
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling Flip Video USB Port, USB Port: passo 10, immagine 1 di 1
      • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling Flip Video USB Port: passo 11, immagine 1 di 1
      • Lift wire out of the outer shell slot.
      • The wire mount should stay attached to the wire.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling Flip Video USB Port: passo 12, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Use tweezers to remove the spring that holds the port door shut.
      • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling Flip Video USB Port: passo 13, immagine 1 di 1
      • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    5. Disassembling Flip Video USB Port: passo 14, immagine 1 di 1
      • Remove the USB port cover.
      Chiedi a FixBot
      Aggiungi Commento
    6. Disassembling Flip Video USB Port: passo 15, immagine 1 di 1
      • Remove the USB slider.
      Chiedi a FixBot
      Aggiungi Commento
    7. Disassembling Flip Video USB Port: passo 16, immagine 1 di 1
      • Lift out the USB port slowly.
      • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Elizabeth
Membro da: 04/15/10
100 Reputazione
6 guide realizzate
Cal Poly, Team 26-21, Regan Spring 2010 Membro di Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 35
Tutti i Tempi: 4,521
