Salta al contenuto principale
Disassembling Epson PPC650 Replacing Flash
Cosa ti serve
    1. Disassembling Epson PPC650 Replacing Flash, Case: passo 1, immagine 1 di 3 Disassembling Epson PPC650 Replacing Flash, Case: passo 1, immagine 2 di 3 Disassembling Epson PPC650 Replacing Flash, Case: passo 1, immagine 3 di 3
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling Epson PPC650 Replacing Flash: passo 2, immagine 1 di 1
      • Remove the two screws on the rounded side of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    3. Disassembling Epson PPC650 Replacing Flash: passo 3, immagine 1 di 2 Disassembling Epson PPC650 Replacing Flash: passo 3, immagine 2 di 2
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      Chiedi a FixBot
      Aggiungi Commento
    4. Disassembling Epson PPC650 Replacing Flash: passo 4, immagine 1 di 1
      • Remove the four screws from the bottom of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    5. Disassembling Epson PPC650 Replacing Flash: passo 5, immagine 1 di 3 Disassembling Epson PPC650 Replacing Flash: passo 5, immagine 2 di 3 Disassembling Epson PPC650 Replacing Flash: passo 5, immagine 3 di 3
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: passo 6, immagine 1 di 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: passo 6, immagine 2 di 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: passo 6, immagine 3 di 3
      • Optional: Remove two black screws from top of camera on the flash side for more working space.
      Chiedi a FixBot
      Aggiungi Commento
    2. Disassembling Epson PPC650 Replacing Flash: passo 7, immagine 1 di 1
      • Remove clear rubber band holding flash in line with wiring.
      Chiedi a FixBot
      Aggiungi Commento
      • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
      Chiedi a FixBot
      Aggiungi Commento
      • Connect new flash by soldering copper ends to their respective ends to new flash element.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Xan Danes
Membro da: 02/14/13
134 Reputazione
Una guida realizzata
Ohio State, Team 1-5, Buehl Spring 2013 Membro di Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 668
