Salta al contenuto principale
Disassembling Chef's Choice M115 Case
Cosa ti serve
  1. Disassembling Chef's Choice M115 Case, Case: passo 1, immagine 1 di 2 Disassembling Chef's Choice M115 Case, Case: passo 1, immagine 2 di 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Disassembling Chef's Choice M115 Case: passo 2, immagine 1 di 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Disassembling Chef's Choice M115 Case: passo 3, immagine 1 di 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Disassembling Chef's Choice M115 Case: passo 4, immagine 1 di 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
Conclusione
Altre 4 persone hanno completato questa guida.
IUPUI, Team 3-3, Harley Fall 2015 Membro di IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Membri
14 Guide realizzate
2Commenti sulla guida
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Replica Condividi
Thank you. I have the M120 which I believe is similar. Only the three deeply recessed screws need to be removed to take the case apart. The others hold internal components in place.
John Slater - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 65
Tutti i Tempi: 2,284
