Salta al contenuto principale
Digitech XC- 5206 Dual Speaker Replacement
Cosa ti serve
  1. Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: passo 1, immagine 1 di 2 Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: passo 1, immagine 2 di 2
    • Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
    • Angle the spudger and use your fingers to pry the panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Dual Speaker Replacement: passo 2, immagine 1 di 3 Digitech XC- 5206 Dual Speaker Replacement: passo 2, immagine 2 di 3 Digitech XC- 5206 Dual Speaker Replacement: passo 2, immagine 3 di 3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Dual Speaker Replacement: passo 3, immagine 1 di 2 Digitech XC- 5206 Dual Speaker Replacement: passo 3, immagine 2 di 2
    • Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion.
    • Push speaker bulbs forward and out of slot.
  4. Digitech XC- 5206 Dual Speaker Replacement: passo 4, immagine 1 di 2 Digitech XC- 5206 Dual Speaker Replacement: passo 4, immagine 2 di 2
    • Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 231
