Salta al contenuto principale
Dell XPS 15 9575 Screen Replacement
Cosa ti serve
  1. Dell XPS 15 9575 Screen  Replacement, Bottom Cover: passo 1, immagine 1 di 3 Dell XPS 15 9575 Screen  Replacement, Bottom Cover: passo 1, immagine 2 di 3 Dell XPS 15 9575 Screen  Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Screen  Replacement: passo 2, immagine 1 di 1
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Screen  Replacement, Heat Sink: passo 3, immagine 1 di 2 Dell XPS 15 9575 Screen  Replacement, Heat Sink: passo 3, immagine 2 di 2
    • Wedge the plastic opening pick in between the aluminum cover and the motherboard.
    • Gently pull up popping off the cover and revealing the rest of the heat sink.
    • The aluminum cover will slot into small clamps on all sides, so be sure to align all sides within the clamps during reinstallation.
  4. Dell XPS 15 9575 Screen  Replacement: passo 4, immagine 1 di 2 Dell XPS 15 9575 Screen  Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove all five black 3.2mm screws.
  5. Dell XPS 15 9575 Screen  Replacement: passo 5, immagine 1 di 2 Dell XPS 15 9575 Screen  Replacement: passo 5, immagine 2 di 2
    • Wedge the plastic opening pick in between the edge of the heat sink and the aluminum perimeter with care not to scratch the CPU beneath.
    • Gently pry up on the heat sink until it is loose enough for you to remove. Then grab and remove the heat sink.
    • If it does not work in the first position that you tried, try another. Do not pry too much in one position because it could damage the components beneath the heat sink.
    • Clean and Reapply the Thermal Paste during reinstallation.
  6. Dell XPS 15 9575 Screen  Replacement, Screen: passo 6, immagine 1 di 3 Dell XPS 15 9575 Screen  Replacement, Screen: passo 6, immagine 2 di 3 Dell XPS 15 9575 Screen  Replacement, Screen: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a plastic opening pick to pop up the small black tab of the touchscreen ZIF connector.
    • The black tab should not pop out, but rather hinge upwards. It will release the ribbon cable from its connector.
    • Use the tweezers to remove the orange ribbon cable from the connector and peel the ribbon from the backboard, as it's secured with a light adhesive.
  7. Dell XPS 15 9575 Screen  Replacement: passo 7, immagine 1 di 3 Dell XPS 15 9575 Screen  Replacement: passo 7, immagine 2 di 3 Dell XPS 15 9575 Screen  Replacement: passo 7, immagine 3 di 3
    • Two silver screws are holding down the aluminium dust cover protecting the display connections.
    • Use the Phillips #0 screwdriver to remove two 3.2 mm silver screws.
    • Use the tweezers to remove the grey cover.
    • Under the cover, you will see one white wire and one black wire.
    • Use the tweezers and gently pull straight up on each of the coaxial cables to disconnect them from their specialized brackets.
    • Reposition the tweezers farther up on the wire and pull forward to remove the wires from the plastic guides that hold the them in place.
  8. Dell XPS 15 9575 Screen  Replacement: passo 8, immagine 1 di 3 Dell XPS 15 9575 Screen  Replacement: passo 8, immagine 2 di 3 Dell XPS 15 9575 Screen  Replacement: passo 8, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the two 3.2 mm black screws holding down the cover.
    • Now use the tweezers to carefully remove the silver cover from the backboard.
    • Under the cover you will see the display cable fused to a rectangular adapter.
    • Gently wedge the plastic opening pick in between the display cable and the backboard.
    • Gently pry up disconnecting the adapter with the display cable from its bracket.
  9. Dell XPS 15 9575 Screen  Replacement: passo 9, immagine 1 di 3 Dell XPS 15 9575 Screen  Replacement: passo 9, immagine 2 di 3 Dell XPS 15 9575 Screen  Replacement: passo 9, immagine 3 di 3
    • Open the screen until it is 180 degrees from the keyboard and then lay the laptop face down.
    • Use the Phillips #0 screwdriver to remove the six, 6.3 mm, silver screws securing the hinges.
  10. Dell XPS 15 9575 Screen  Replacement: passo 10, immagine 1 di 1
    • Make sure all previous steps are done before this step, as this step could result in damaging the computer.
    • Grip the screen assembly and gently pull straight up from the table removing the entire assembly.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,677
