Salta al contenuto principale
Dell XPS 14 L401X Battery Replacement
Cosa ti serve
  1. Dell XPS 14 L401X Battery Replacement, Battery: passo 1, immagine 1 di 2 Dell XPS 14 L401X Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Mark
Membro da: 10/19/17
655 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 718
