Salta al contenuto principale
Dell XPS 13 9310 Lower Case Replacement
Cosa ti serve
  1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: passo 1, immagine 1 di 2 Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: passo 1, immagine 2 di 2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: passo 2, immagine 1 di 2 Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: passo 2, immagine 2 di 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: passo 3, immagine 1 di 2 Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: passo 3, immagine 2 di 2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: passo 4, immagine 1 di 3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: passo 4, immagine 2 di 3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: passo 4, immagine 3 di 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Lower Case Replacement: passo 5, immagine 1 di 3 Dell XPS 13 9310 Lower Case Replacement: passo 5, immagine 2 di 3 Dell XPS 13 9310 Lower Case Replacement: passo 5, immagine 3 di 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Conclusione
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
Altre 2 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
59.657 Reputazione
430 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 123
Tutti i Tempi: 1,500
