Introduzione
In this guide, we will show you how to remove and replace the battery.
Cosa ti serve
Turn the tablet over.
Remove the screws that secure the back-cover assembly to the display assembly.
Using a plastic scribe, pry up along the edges of the back-cover assembly.
Carefully, lift the back-cover assembly and turn it over.
Remove the screws that secure the battery to the back-cover assembly.
Disconnect the battery cable from the system board.
Lift the battery, along with its cable, off the back-cover assembly.
Altre 4 persone hanno completato questa guida.
Un commento
The 4 screws on the edge are NOT phillips head screws. They appear to be Tork.
