Salta al contenuto principale
Dell Venue 8 Display Replacement
Cosa ti serve
    1. Dell Venue 8 Display Replacement, Rear Case/Midframe: passo 1, immagine 1 di 1
      • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
      • You will hear click sounds as the clips unhinge
      • Remove the back panel of the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Venue 8 Display Replacement: passo 2, immagine 1 di 3 Dell Venue 8 Display Replacement: passo 2, immagine 2 di 3 Dell Venue 8 Display Replacement: passo 2, immagine 3 di 3
      • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
      • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
      • 4.45mm Silver screws
      • 3.6mm Black screws
      • Gently snap the perimeter clips open, and remove the internal plastic case.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Venue 8 Display Replacement, Battery: passo 3, immagine 1 di 1
      • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Venue 8 Display Replacement: passo 4, immagine 1 di 1
      • Gently pry the battery away from the device with the plastic opening tool to remove it.
      • The battery is held on to the tablet by a light adhesive
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Venue 8 Display Replacement, Speaker: passo 5, immagine 1 di 1
      • Using your plastic opening tool, unclip the speaker connection from the logic board.
      • Caution: Pull directly up, not out, on the connection
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Venue 8 Display Replacement: passo 6, immagine 1 di 1
      • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
      • The speaker is held on by light adhesive
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Venue 8 Display Replacement, Display: passo 7, immagine 1 di 2 Dell Venue 8 Display Replacement, Display: passo 7, immagine 2 di 2
      • Disconnect the display clip found next to the speaker.
      • Disconnect the Display connection located at the top of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Venue 8 Display Replacement: passo 8, immagine 1 di 1
      • Unclip the logic board from the Display.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Mitul
Membro da: 02/19/15
673 Reputazione
Una guida realizzata
USF Tampa, Team 9-2, Leahy Winter 2015 Membro di USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Membri
12 guide realizzate
2Commenti sulla guida
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - Rispondi Condividi
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 13
Ultimi 30 giorni: 38
Tutti i Tempi: 7,710
