Salta al contenuto principale
Dell Precision T3400 Video Card Replacement
    1. Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: passo 1, immagine 1 di 2 Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: passo 1, immagine 2 di 2
      • Lay the computer on its side so the panel faces up.
      • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
      • Make sure the computer is on its side before you begin replacing any parts.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: passo 2, immagine 1 di 1
      • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
      • Make sure you ground yourself to prevent static discharge
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: passo 3, immagine 1 di 2 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: passo 3, immagine 2 di 2
      • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dell Precision T3400 Video Card Replacement, Remove the video card: passo 4, immagine 1 di 1
      • Hold the card by its top corner and metal bracket and pull it out of its slot.
      Chiedi a FixBot
      Aggiungi Commento
    4. Dell Precision T3400 Video Card Replacement, Install the new video card: passo 5, immagine 1 di 2 Dell Precision T3400 Video Card Replacement, Install the new video card: passo 5, immagine 2 di 2
      • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
      • Close the card door and move the blue plastic secure lever back into place.\
      • Ensure that the card you are replacing the existing card with meets wattage and connectivity requirements. Do not force a card into the slot.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
Altre 8 persone hanno completato questa guida.
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Membro di UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 Membri
22 guide realizzate
1Commento della guida
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
Maxime Raguenet - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 58
Tutti i Tempi: 7,422
