Salta al contenuto principale
Dell Precision M4700 Memory Module Replacement
Cosa ti serve
  1. Dell Precision M4700 Memory Module Replacement, Battery: passo 1, immagine 1 di 2 Dell Precision M4700 Memory Module Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Precision M4700 Memory Module Replacement, Base Cover: passo 2, immagine 1 di 2 Dell Precision M4700 Memory Module Replacement, Base Cover: passo 2, immagine 2 di 2
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
    Chiedi a FixBot
    Aggiungi Commento
  3. Dell Precision M4700 Memory Module Replacement, Keyboard Trim: passo 3, immagine 1 di 2 Dell Precision M4700 Memory Module Replacement, Keyboard Trim: passo 3, immagine 2 di 2
    • Pry up the keyboard trim starting from the top-inner edge.
    • Pry up the bottom edge of the keyboard trim from the top-inner edge.
    Chiedi a FixBot
    Aggiungi Commento
  4. Dell Precision M4700 Memory Module Replacement, Keyboard: passo 4, immagine 1 di 3 Dell Precision M4700 Memory Module Replacement, Keyboard: passo 4, immagine 2 di 3 Dell Precision M4700 Memory Module Replacement, Keyboard: passo 4, immagine 3 di 3
    • Remove the screws that secure the keyboard to the computer.
    • Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
    • Disconnect the keyboard-data cable from the system board and remove the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Dell Precision M4700 Memory Module Replacement, Memory Module: passo 5, immagine 1 di 1
    • Flip Computer To its Back.
    • Pry the retention clips away from the memory module until it pops up. Lift up the memory module and remove it from the computer.
    Chiedi a FixBot
    Aggiungi Commento
  6. Dell Precision M4700 Memory Module Replacement: passo 6, immagine 1 di 1
    • Flip the Computer To its Top.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
2.003 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 20
Tutti i Tempi: 1,359
