Introduzione
This guide takes the user through the steps of replacing this devices CPU.
The CPU is the brain of the computer. It is the part of the computer that performs calculations, actions, and runs programs. You may have a bad CPU if your system starts and then shuts down immediately.
Before using this guide, be sure to review the Dell Precision M4700 Troubleshooting Often times, checking the cooling fans to make sure they are working will help solve the issue.
Cosa ti serve
Slide the release latch to unlock the battery.
Flip and remove the battery from the computer.
Pry up the keyboard trim starting from the top-inner edge with a plastic opening tool or spudger.
Pry up the bottom edge of the keyboard trim from the top-inner edge with a plastic opening tool or spudger.
Remove the four 3mm screws that secure the keyboard to the computer with a Phillips #00 screwdriver.
Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
Disconnect the keyboard-data cable from the system board by flipping up the locking tab of the ZIF connector and gently pulling out the cable.
Remove the keyboard.
Altre 2 persone hanno completato questa guida.
