Salta al contenuto principale
Dell Precision M4400 Memory Module Replacement
Cosa ti serve
  1. Dell Precision M4400 Memory Module Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Precision M4400 Memory Module Replacement, Base Cover: passo 2, immagine 1 di 1
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Dell Precision M4400 Memory Module Replacement, Memory Module: passo 3, immagine 1 di 1
    • To remove the DIMM module, spread away the retaining clips from the side edges of the memory module and lift the free edge of the module so that it sits at about a 30-degree angle to the system board.
    • Grasp the module at the side edges and pull it straight away from the connector. Place the module into anti-static packaging such as an anti- static bag.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
2.003 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 45
Tutti i Tempi: 734
