Salta al contenuto principale
Dell Photo Printer 720 Encoder Strip Replacement
Cosa ti serve
    1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, immagine 1 di 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, immagine 2 di 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, immagine 3 di 3
      • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Photo Printer 720 Encoder Strip Replacement: passo 2, immagine 1 di 3 Dell Photo Printer 720 Encoder Strip Replacement: passo 2, immagine 2 di 3 Dell Photo Printer 720 Encoder Strip Replacement: passo 2, immagine 3 di 3
      • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
      • Pry apart the light grey cover from the black base.
      • Gently flip the printer upright to its standard position and carefully lift off the cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dell Photo Printer 720 Encoder Strip Replacement: passo 3, immagine 1 di 2 Dell Photo Printer 720 Encoder Strip Replacement: passo 3, immagine 2 di 2
      • Slide the ink cartridge from the right side to the middle left so it is out of the way.
      Chiedi a FixBot
      Aggiungi Commento
    4. Dell Photo Printer 720 Encoder Strip Replacement: passo 4, immagine 1 di 3 Dell Photo Printer 720 Encoder Strip Replacement: passo 4, immagine 2 di 3 Dell Photo Printer 720 Encoder Strip Replacement: passo 4, immagine 3 di 3
      • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
      • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
      • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 33
Tutti i Tempi: 1,035
