Salta al contenuto principale
Dell Optiplex 745 Small Form Factor RAM Replacement
    1. Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: passo 1, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: passo 1, immagine 2 di 2
      • Pull the tab and the lid will pop up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Optiplex 745 Small Form Factor RAM Replacement: passo 2, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement: passo 2, immagine 2 di 2
      • Grab the lid and pull it up and off.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: passo 3, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: passo 3, immagine 2 di 2
      • Pull out both sets of cables from the side of the optical drive.
      • Both cables are plugged into the drive right next to each other.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: passo 4, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: passo 4, immagine 2 di 2
      • Pull the tab up holding the optical drive in place.
      • Slide the optical drive out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: passo 5, immagine 1 di 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: passo 5, immagine 2 di 2
      • Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Optiplex 745 Small Form Factor RAM Replacement, Lifting the RAM stick out of the case: passo 6, immagine 1 di 1
      • Gently lift the RAM stick up and out of the case.
      • When inserting a RAM stick, press firmly down into the slot until the white tabs lock into both sides of the stick.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Brandon Cooper
Membro da: 09/28/14
486 Reputazione
Una guida realizzata
Cal Poly, Team 13-10, Forte Fall 2014 Membro di Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
6 Membri
24 guide realizzate
1Commento della guida
Dell master. I'm going to be the best repair pro on this side of the south side.
fixitbrosmsus - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 33
Tutti i Tempi: 2,198
