Introduzione
Use this guide to replace the charging port in your Dell Latitude 7490.
Cosa ti serve
Unplug all cables and fully shut down your laptop.
Flip your laptop over so the rubber feet strips are facing up.
Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
Insert the long side of an opening pick between the top right corner of the back cover and frame.
Pry the back cover up to release the clips securing the top right corner.
Slide the opening pick down the right edge and around the bottom right corner to release the clips.
Grip the plastic tab on the battery connector and pull straight up to disconnect it.
Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the charging port bracket.
Remove the bracket.
Grip the charging port cable just below its connector.
Pull the connector straight out of its socket and remove the charging port.
