Salta al contenuto principale
Dell Inspiron n5050 RAM Replacement
Cosa ti serve
    1. Dell Inspiron n5050 RAM Replacement, Battery: passo 1, immagine 1 di 1
      • Flip your laptop over to view the bottom and locate the two locks.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Inspiron n5050 RAM Replacement: passo 2, immagine 1 di 1
      • Slide the two locks away from each other.
      • Sliding these locks will loosen the battery to allow removal.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dell Inspiron n5050 RAM Replacement: passo 3, immagine 1 di 2 Dell Inspiron n5050 RAM Replacement: passo 3, immagine 2 di 2
      • Pull battery out of the laptop.
      • Your laptop's battery should be completely removed.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Inspiron n5050 RAM Replacement, Keyboard: passo 4, immagine 1 di 2 Dell Inspiron n5050 RAM Replacement, Keyboard: passo 4, immagine 2 di 2
      • Flip the laptop right side up. Open the laptop.
      • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
      • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Inspiron n5050 RAM Replacement: passo 5, immagine 1 di 3 Dell Inspiron n5050 RAM Replacement: passo 5, immagine 2 di 3 Dell Inspiron n5050 RAM Replacement: passo 5, immagine 3 di 3
      • Gently flip the data cable latch away from the data cable with flat side of spudger.
      • Lift the cable up and out.
      • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
      • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell Inspiron n5050 RAM Replacement, RAM: passo 6, immagine 1 di 3 Dell Inspiron n5050 RAM Replacement, RAM: passo 6, immagine 2 di 3 Dell Inspiron n5050 RAM Replacement, RAM: passo 6, immagine 3 di 3
      • Locate RAM
      • Push outwards on both retaining clips, the RAM will pop up slightly when it is free from the clips.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell Inspiron n5050 RAM Replacement: passo 7, immagine 1 di 1
      • The RAM will pop up, and then you can slide it out at the same angle it is at.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Tyler
Membro da: 06/19/12
5.088 Reputazione
16 guide realizzate
TechForce Membro di TechForce
Business
2 Membri
185 guide realizzate
2Commenti sulla guida
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - Rispondi Condividi
Dell laptop inspion15 _M5040 N5050
Anas Shaikh - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 27
Ultimi 30 giorni: 114
Tutti i Tempi: 11,222
