Salta al contenuto principale
Dell Inspiron N5030 RAM Replacement
Cosa ti serve
  1. Dell Inspiron N5030 RAM Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron N5030 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Inspiron N5030 RAM Replacement: passo 2, immagine 1 di 2 Dell Inspiron N5030 RAM Replacement: passo 2, immagine 2 di 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Dell Inspiron N5030 RAM Replacement, Keyboard: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. Dell Inspiron N5030 RAM Replacement: passo 4, immagine 1 di 1
    • Flip over the laptop and open it so that the screen faces you.
    Chiedi a FixBot
    Aggiungi Commento
  5. Dell Inspiron N5030 RAM Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  6. Dell Inspiron N5030 RAM Replacement: passo 6, immagine 1 di 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Dell Inspiron N5030 RAM Replacement: passo 7, immagine 1 di 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  8. Dell Inspiron N5030 RAM Replacement: passo 8, immagine 1 di 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  9. Dell Inspiron N5030 RAM Replacement: passo 9, immagine 1 di 1
    • Remove the top keyboard panel.
    Chiedi a FixBot
    Aggiungi Commento
  10. Dell Inspiron N5030 RAM Replacement, RAM: passo 10, immagine 1 di 1
    • Place your fingers on the two metal tabs on the edges of the RAM.
    • Push on the tabs in the opposite direction.
    • The top RAM board will pop up after you push on the metal tabs.
    Chiedi a FixBot
    Aggiungi Commento
  11. Dell Inspiron N5030 RAM Replacement: passo 11, immagine 1 di 1
    • Pull the top RAM board out with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  12. Dell Inspiron N5030 RAM Replacement: passo 12, immagine 1 di 3 Dell Inspiron N5030 RAM Replacement: passo 12, immagine 2 di 3 Dell Inspiron N5030 RAM Replacement: passo 12, immagine 3 di 3
    • Repeat the above RAM board steps for the second RAM board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Rodrigo Perez
Membro da: 04/23/14
230 Reputazione
Una guida realizzata
Cal Poly, Team 10-59, Amido Spring 2014 Membro di Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Membri
5 guide realizzate
3Commenti sulla guida
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
swestonj - Rispondi Condividi
swestonj is incorrect. The manual clearly states that you must remove the screws:
Service Manual
Removing the Keyboard
1. Follow the instructions in Before You Begin.
2. Remove the battery (see Removing the Battery).
3. Remove the two screws that secure the keyboard to the computer base.
etc.
mike - Rispondi Condividi
зависит от целей. озу можно поменять не разбирая всё. а вот пзу придется все разобрать. я так и не понял сьёмный тут проц или припаян. вроде есть защелка
артемий Александровна троицкий - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 32
Tutti i Tempi: 6,081
