Salta al contenuto principale
Dell Inspiron 5555 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 5555 Keyboard  Replacement, Battery: passo 1, immagine 1 di 1
    • Close the laptop and lay it flat, logo side down.
    • Make sure that the battery is visible and at the top of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Inspiron 5555 Keyboard  Replacement: passo 2, immagine 1 di 3 Dell Inspiron 5555 Keyboard  Replacement: passo 2, immagine 2 di 3 Dell Inspiron 5555 Keyboard  Replacement: passo 2, immagine 3 di 3
    • Push the lock switch to the left to pop out the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Dell Inspiron 5555 Keyboard  Replacement: passo 3, immagine 1 di 3 Dell Inspiron 5555 Keyboard  Replacement: passo 3, immagine 2 di 3 Dell Inspiron 5555 Keyboard  Replacement: passo 3, immagine 3 di 3
    • When the battery pops out, lift it so that it comes out completely.
    Chiedi a FixBot
    Aggiungi Commento
  4. Dell Inspiron 5555 Keyboard  Replacement, Keyboard: passo 4, immagine 1 di 3 Dell Inspiron 5555 Keyboard  Replacement, Keyboard: passo 4, immagine 2 di 3 Dell Inspiron 5555 Keyboard  Replacement, Keyboard: passo 4, immagine 3 di 3
    • Turn the laptop over and open the device.
    • Insert the flat end of the spudger into the five notches located at the top of the keyboard and pry the keyboard up by pushing down and up.
    Chiedi a FixBot
    Aggiungi Commento
  5. Dell Inspiron 5555 Keyboard  Replacement: passo 5, immagine 1 di 2 Dell Inspiron 5555 Keyboard  Replacement: passo 5, immagine 2 di 2
    • Lift up and slide back to release the six notches from the bottom of the keyboard.
    • Be careful not to lift the keyboard up all the way because it is still connected to the laptop by a cable on the bottom.
    Chiedi a FixBot
    Aggiungi Commento
  6. Dell Inspiron 5555 Keyboard  Replacement: passo 6, immagine 1 di 3 Dell Inspiron 5555 Keyboard  Replacement: passo 6, immagine 2 di 3 Dell Inspiron 5555 Keyboard  Replacement: passo 6, immagine 3 di 3
    • Flip the keyboard upside down to access the keyboard cable.
    • Using the flat end of the spudger, flip the black tab securing the keyboard cable up to remove the keyboard cable.
    • Remove the keyboard by lifting it off of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
Thank you so much for this guide! The steps were clear and concise.
Scott Kerman - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 30
Tutti i Tempi: 1,195
