Salta al contenuto principale
Dell G15-5510 Gaming Back Cover Replacement
Cosa ti serve
  1. Dell G15-5510 Gaming Back Cover Replacement, Unfasten the back cover: passo 1, immagine 1 di 2 Dell G15-5510 Gaming Back Cover Replacement, Unfasten the back cover: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four screws securing the back cover.
    • Two 8 mm screws
    • Two 5.8 mm screws
    • Loosen the four captive screws.
  2. Dell G15-5510 Gaming Back Cover Replacement, Unclip the front corners: passo 2, immagine 1 di 2 Dell G15-5510 Gaming Back Cover Replacement, Unclip the front corners: passo 2, immagine 2 di 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry upward to release clips holding the cover in place.
    • Listen for a loud click to indicate a clip being released.
  3. Dell G15-5510 Gaming Back Cover Replacement: passo 3, immagine 1 di 2 Dell G15-5510 Gaming Back Cover Replacement: passo 3, immagine 2 di 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5510 Gaming Back Cover Replacement, Remove the back cover: passo 4, immagine 1 di 3 Dell G15-5510 Gaming Back Cover Replacement, Remove the back cover: passo 4, immagine 2 di 3 Dell G15-5510 Gaming Back Cover Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
Clay Eickemeyer
Membro da: 09/19/22
81.589 Reputazione
455 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.372 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 161
Tutti i Tempi: 2,426
