Salta al contenuto principale
Dell E193FPc Interface Buttons Replacement
Cosa ti serve
    1. Dell E193FPc Interface Buttons Replacement, Stand: passo 1, immagine 1 di 1
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell E193FPc Interface Buttons Replacement: passo 2, immagine 1 di 1
      • Gently lift and pull away the stand at a slight angle away from the monitor.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell E193FPc Interface Buttons Replacement, Display Bezel: passo 3, immagine 1 di 2 Dell E193FPc Interface Buttons Replacement, Display Bezel: passo 3, immagine 2 di 2
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell E193FPc Interface Buttons Replacement: passo 4, immagine 1 di 2 Dell E193FPc Interface Buttons Replacement: passo 4, immagine 2 di 2
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dell E193FPc Interface Buttons Replacement: passo 5, immagine 1 di 3 Dell E193FPc Interface Buttons Replacement: passo 5, immagine 2 di 3 Dell E193FPc Interface Buttons Replacement: passo 5, immagine 3 di 3
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell E193FPc Interface Buttons Replacement, Interface Buttons: passo 6, immagine 1 di 1
      • Behind the front panel of the plastic cover lies the button strip.
      • Remove the buttons by gently pulling up on the strip.
      • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Charley Grove
Membro da: 10/10/11
101 Reputazione
Una guida realizzata
Cal Poly, Team 5-36, Amido Fall 2011 Membro di Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Membri
24 guide realizzate
1Commento della guida
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 33
Tutti i Tempi: 2,684
