Salta al contenuto principale
Dell Alienware 14 Memory Module Replacement
Cosa ti serve
  1. Dell Alienware 14 Memory Module Replacement, Close the Display: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Alienware 14 Memory Module Replacement, Remove the Screws: passo 2, immagine 1 di 2 Dell Alienware 14 Memory Module Replacement, Remove the Screws: passo 2, immagine 2 di 2
    • Remove the screws that secure the base cover to the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  3. Dell Alienware 14 Memory Module Replacement, Slide and Lift the Base Cover: passo 3, immagine 1 di 1
    • Slide and lift the base cover off the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  4. Dell Alienware 14 Memory Module Replacement, Align the Tabs: passo 4, immagine 1 di 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Dell Alienware 14 Memory Module Replacement, Replace the Screws: passo 5, immagine 1 di 1
    • Replace the screws that secure the base cover to the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  6. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: passo 6, immagine 1 di 1
    • Turn the computer over and open the display.
    Chiedi a FixBot
    Aggiungi Commento
  7. Dell Alienware 14 Memory Module Replacement, Disconnecting the Battery Cable: passo 7, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  8. Dell Alienware 14 Memory Module Replacement, Remove the Screws: passo 8, immagine 1 di 1
    • Remove the screws that secure the battery to the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  9. Dell Alienware 14 Memory Module Replacement, Using the Battery Cable: passo 9, immagine 1 di 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  10. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: passo 10, immagine 1 di 1
    • Turn the computer over and open the display as far as possible.
    Chiedi a FixBot
    Aggiungi Commento
  11. Dell Alienware 14 Memory Module Replacement, The Power Button: passo 11, immagine 1 di 1
    • Press and hold the power button for five seconds to ground the system board.
    Chiedi a FixBot
    Aggiungi Commento
    • Close the display and turn the computer over.
    Chiedi a FixBot
    Aggiungi Commento
  12. Dell Alienware 14 Memory Module Replacement, Align the Tabs: passo 13, immagine 1 di 1
    • Align the tabs on the NEW battery with the slots on the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  13. Dell Alienware 14 Memory Module Replacement, Align the Screw Holes: passo 14, immagine 1 di 1
    • Align the screw holes on the battery with the screw holes on the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  14. Dell Alienware 14 Memory Module Replacement, Replace the Screws: passo 15, immagine 1 di 1
    • Replace the screws that secure the battery to the computer base.
    Chiedi a FixBot
    Aggiungi Commento
  15. Dell Alienware 14 Memory Module Replacement, Connect the Battery Cable: passo 16, immagine 1 di 1
    • Connect the battery cable to the system-board connector.
    Chiedi a FixBot
    Aggiungi Commento
  16. Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: passo 17, immagine 1 di 3 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: passo 17, immagine 2 di 3 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: passo 17, immagine 3 di 3
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    Chiedi a FixBot
    Aggiungi Commento
  17. Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: passo 18, immagine 1 di 2 Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: passo 18, immagine 2 di 2
    • Remove the memory module from the memory-module connector.
    Chiedi a FixBot
    Aggiungi Commento
  18. Dell Alienware 14 Memory Module Replacement, Align the Notch: passo 19, immagine 1 di 2 Dell Alienware 14 Memory Module Replacement, Align the Notch: passo 19, immagine 2 di 2
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
    Chiedi a FixBot
    Aggiungi Commento
  19. Dell Alienware 14 Memory Module Replacement, Slide the Memory Module: passo 20, immagine 1 di 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Terrence15
Membro da: 12/18/17
80.125 Reputazione
441 guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
2.003 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 29
Tutti i Tempi: 558
