Salta al contenuto principale
Dell Adamo 13 Battery Replacement
  1. Dell Adamo 13 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Battery Replacement: passo 3, immagine 1 di 1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 495
