Salta al contenuto principale
Dell AC511 Volume Knob Replacement
Cosa ti serve
    1. Dell AC511 Volume Knob Replacement, Front Panel: passo 1, immagine 1 di 3 Dell AC511 Volume Knob Replacement, Front Panel: passo 1, immagine 2 di 3 Dell AC511 Volume Knob Replacement, Front Panel: passo 1, immagine 3 di 3
      • Use a Jimmy to peel off the screen stuck to the front of the speaker.
      • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
      • Be careful to avoid damage to the rest of the speaker and especially to yourself.
      • Don't worry if it tears; use the Jimmy again to peel off the rest.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell AC511 Volume Knob Replacement: passo 2, immagine 1 di 2 Dell AC511 Volume Knob Replacement: passo 2, immagine 2 di 2
      • Remove ten 6 mm screws using a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dell AC511 Volume Knob Replacement: passo 3, immagine 1 di 2 Dell AC511 Volume Knob Replacement: passo 3, immagine 2 di 2
      • Lift the front panel off of the rest of the device.
      • The speakers will still be attached to the front panel. Being too rough could damage them.
      • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
      • Remove the front panel from the device.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell AC511 Volume Knob Replacement, Volume Knob: passo 4, immagine 1 di 1
      • Apply a light downward pressure on the circuit board next to the volume control.
      • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell AC511 Volume Knob Replacement: passo 5, immagine 1 di 1
      • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
      • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 29
Tutti i Tempi: 391
