Introduzione
The wound wires of a field coil can fail, causing a drill to function poorly or not at all. Use this guide to replace a broken field in the DeWalt DWD112.
Cosa ti serve
Move the black wire clear from any obstruction.
Repeat this step for the white wire and the red wire.
1Commento della guida
as a recommendation aimed at some or mark with a piece of ribbon cables disconnected the trigger with the contact number that corresponds to the rearm the drill going to not reverse the change control rotation.
