Introduzione
You will need to follow this guide step-by-step in order to separate the device into two piece. In doing so you will be able to replace the front panel, if damaged, as well as get to the other components inside of the device.
Cosa ti serve
Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
Altre 2 persone hanno completato questa guida.
