Salta al contenuto principale
DCC-3200 Faulty Power Cord Replacement
Cosa ti serve
  1. DCC-3200 Faulty Power Cord Replacement, Faulty Power Cord: passo 1, immagine 1 di 1
    • First, please be sure that the device is unplugged and that there is no water in the reservoir.
    • Check the power cord for frays or cracks.
  2. DCC-3200 Faulty Power Cord Replacement: passo 2, immagine 1 di 1
    • If the cord appears fine, please flip the device upside-down and unscrew the 4 screws on the bottom.
  3. DCC-3200 Faulty Power Cord Replacement: passo 3, immagine 1 di 1
    • Remove the bottom panel and unclip the power cord from the panel.
  4. DCC-3200 Faulty Power Cord Replacement: passo 4, immagine 1 di 1
    • With the front facing towards you upside down, to the top left of the circular hotplate is a beige circuit board with two screws on either side holding it in. Please unscrew them.
  5. DCC-3200 Faulty Power Cord Replacement: passo 5, immagine 1 di 1
    • Carefully remove the circuit board and unplug the gray ribbon wire that is plugged into it.
  6. DCC-3200 Faulty Power Cord Replacement: passo 6, immagine 1 di 1
    • Check to see if the power cord is connected properly to the circuit board.
  7. DCC-3200 Faulty Power Cord Replacement: passo 7, immagine 1 di 1
    • Strip the wire and twist with the other or solder it back on.
Conclusione
Hamad Khan
Membro da: 03/04/16
385 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,017
