Salta al contenuto principale
Wire Stripping
Cosa ti serve
    1. Wire Stripping, Wire Stripping: passo 1, immagine 1 di 1
      • Match your gauge of wire to the gauge on a wire stripper.
      • Some wire strippers will have two gauge sizes for the same hole, one for solid wire and one for stranded. Make sure you use the right one for the wire you are stripping!
      Chiedi a FixBot
      Aggiungi Commento
    2. Wire Stripping: passo 2, immagine 1 di 1
      • Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
      • You can strip more than 1/4" at a time, but the effort becomes harder. About 1/2-5/8" (13-16 mm) is the most you should probably attempt.
      Chiedi a FixBot
      Aggiungi Commento
    3. Wire Stripping: passo 3, immagine 1 di 1
      • While squeezing, pull the stripper toward the end of the wire. This should expose some of the wire by removing its insulation.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
Altre 23 persone hanno completato questa guida.
nat coll
Membro da: 09/27/12
859 Reputazione
14 guide realizzate
Cal Poly, Team 7-53, Forte Fall 2012 Membro di Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membri
61 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 53
Ultimi 30 giorni: 331
Tutti i Tempi: 13,174
