Introduzione
The motherboard is the main hub of the router. It is responsible for all the functions of the router. Problems like a lack of connection, water spillage on router, fire on router, will all require a replacement of the mother board.
Cosa ti serve
Orient the router so the narrow end of the router faces you and the ports face away from you.
The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
Strumento utilizzato in questo passaggio:Heavy-Duty Spudger$4.99
Pry off the antenna connectors using a heavy-duty spudger.
Altre 3 persone hanno completato questa guida.
