Salta al contenuto principale
Creative Ziio 7" Battery Replacement
Cosa ti serve
  1. Creative Ziio 7" Battery Replacement, Back Panel: passo 1, immagine 1 di 3 Creative Ziio 7" Battery Replacement, Back Panel: passo 1, immagine 2 di 3 Creative Ziio 7" Battery Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
    Chiedi a FixBot
    Aggiungi Commento
  2. Creative Ziio 7" Battery Replacement, Battery: passo 2, immagine 1 di 3 Creative Ziio 7" Battery Replacement, Battery: passo 2, immagine 2 di 3 Creative Ziio 7" Battery Replacement, Battery: passo 2, immagine 3 di 3
    • Remove the copper plate covering the motherboard by desoldering the ten solder points so that the copper plate is free.
    • The last point is hidden by the soldering iron.
    • Remove the copper plate once all the solder points are undone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Creative Ziio 7" Battery Replacement: passo 3, immagine 1 di 2 Creative Ziio 7" Battery Replacement: passo 3, immagine 2 di 2
    • Remove adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the mother board.
    Chiedi a FixBot
    Aggiungi Commento
  4. Creative Ziio 7" Battery Replacement: passo 4, immagine 1 di 2 Creative Ziio 7" Battery Replacement: passo 4, immagine 2 di 2
    • With a spudger, pry the battery from the back of the LCD screen.
    • The battery is attached with double sided foam tape. When prying, the tape will probably not come apart easy. This will result in the tape tearing and leaving residue.
    Chiedi a FixBot
    Aggiungi Commento
  5. Creative Ziio 7" Battery Replacement: passo 5, immagine 1 di 1
    • Remove old battery and dispose of it responsibly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 14-10, Maness Spring 2013 Membro di Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 27
Tutti i Tempi: 1,284
